Results 1 to 10 of 11
    Dec 2012
    7
    Default 375 extreme plasma cutter problems
    HELP ! I have a 375 extreme plasma cutter with the ice 27t torch. This machine has very few cutting hours on it . When I attempt to fire up the machine (air line hooked up, correct pressure,either power input plug installed, ambient temp aprox 50' f,new electrode and tip installed, nothing visibly wrong with swirl ring) the following happens
    1-green light and 3 orange trouble lights illuminate for about 0.5 of a second
    2-trouble lights go out,green stays illuminated for about 2 seconds.then there is a click, air starts to flow out torch and temperature light comes on and stays on,trigger does nothing, (no Arc)
    3- air continues to flow out of torch without depressing the trigger for 20 seconds then stops but the green light and temperature light stay illuminated and still no action when trigger is pressed
    Any ideas guys?? I already spent $60 in gas hauling it into a service center. They took the cover off and unplugged the plug with 2 small white wires that goes to the center of the control board. The machine then started working. We tested it for a a few seconds in their shop and I took it home. The first time i plugged it in at home -same problem.
    Jul 2009
    Australia
    1,004
    First remove the cover with the power plug removed and check/clean the water trap air filter. Next see where the power switch is pointing to 110 or 220 volts , adjust to suit power you have. With compressed air blow all the dust out.
    The new torch parts are they Miller or a clone this makes a difference.
    Ji
    Grip it and Rip it
    Dec 2012
    7
    sorry- already cleaned out water filter,was absolutely no moisture or other contaminants ,I run a a desiccant filter off the compressor as well as another one just prior to machine along with a regulator to keep correct pressure. have tried both the 110 and 208 plugs along with adjusting dial as required. tip parts were genuine miller. Thoughts?
    Jul 2009
    Australia
    1,004
    With the box back together and the unit powered and aired, turn the amps dial on the front of the machine counter clockwise to 0. Then flick the power switch to on. Air should run out of the torch. Now adjust the air pressure dial clockwise until the air stops running out of the torch. Mine needs to have 90 psi.
    Ji
    Grip it and Rip it
    Dec 2012
    7
    By the way i also checked ,the machine energizes the solenoid that supplies air to the gun about 2 seconds after power switch is turned on and WITHOUT the trigger being depressed...
    Dec 2012
    7
    tried as suggested startind with the amp dial at zero,machine powered and aired- no change ,same sequence of events, same timing, no difference with lower air pressures or recommended
    Jul 2009
    Australia
    1,004
    What was the highest psi air pressure you tried?
    Ji
    Grip it and Rip it
    Dec 2012
    7
    about 115psi
    Jul 2009
    Australia
    1,004
    Post a picture of the torch parts. There should be an o ring, cup, electrode & tip.
    Dont tighten the cup to tight or the electrode can not move backwards when required.
    Ji
    Grip it and Rip it
    Dec 2012
    7
