Results 1 to 8 of 8
    Default Minimum Voltage Setting - Miller 211 MVP
    Miller 211 MVP specs = 150 Amps at 23.5 VDC, 30% duty cycle (230 V).
    Does anyone know what the minimum DC voltage (at 230 volts) is on this machine?
    In other words what voltage does the increment '1' on the voltage dial equal?
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    May 2012
    14
    Hook a DMM up to it and strike an arc..........
    Miller says its ~17v
    Miller 211 MVP
    Lincoln AC 225
    CutMaster 42
    867
    Quote Originally Posted by Thrutraffic View Post
    17 vdc is more than likely the open circuit voltage (OCV) value for that dial setting.
    Under a load, it's probably going to drop down to at least the 15 -16 VDC , and possibly even lower.
    Understand, depending on the wire diameter and shielding gas mix being used, some of the lower range of the voltage dial may not even be usable.
    Just going by the response I got in email from Miller. I only asked them what was the voltage when the dial was at its lowest setting. You're probably right that that changes once you strike an arc. Hopefully though they engineered it to compensate for load in the control circuitry.
    Miller 211 MVP
    Lincoln AC 225
    CutMaster 42
    Nov 2012
    Northern Arizona
    571
    My millermatic 251 will go as low as 14 volts. On the display it will show the actual welding voltage for 5 seconds after striking an arc. The lowest I have seen is 14.1v. That was with the setting at 14v and running .035 wire with c25 gas. I don't remember wfs, maybe 150-180ipm? I was successfully welding 18ga in the 3g position.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Wa
    671
    Just curious , how come you want to know?
    2,967
    Doubtful, they've only been doing this for a few years
