Results 1 to 2 of 2
    woodstock ga
    31
    Default Affordable Tungsten grinder
    Beginner Tig welder,
    Went looking for a grinder that would quickly grind a repeatable profile for the electrode, and would not cost an arm or leg. I read most ideas and there were some good ones. Below is what I came up with for myself. I found a tool, at of all places HF that is fairly stout and looks to be up to the job. The tool is sold as a circular saw blade sharpener, 50 beens.
    With some modifications and reverse engineering I think this is going to give me what I need. If you like it and want more information although it is pretty straight forward. I will be glad to pass along what I know.
    This is the grinder completed
    This shows a post that positions the electrode
    Here is a line scribed in the base to verify the electrode length
    Greg
    Raymore Missouri
    1,910
    I bought one of these a few years back but yours looks different. I did a report here on sharpening blades as well as tungstens. Search "saw blade sharpener" if you want.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
Tags for this Thread
