Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: MM 211 Concerns
    Default MM 211 Concerns
    I finally unboxed my MM211mvp, and cleared my old HH135 off my welder stand, set everything up and gave it a test drive last night. I only had a little bit of time by the time I got everything up and running, but I ran across a couple of issues:
    • I've had _no_ luck with the autoset. I loaded the spool of Hobart .030" ER70S6, set the knob to .030 and I can't get the weld to lay flat to save my life. I get fairly nice tacks, but when I run a bead it looks like I'm building volcanos (they're smooth, not like if I wasn't getting gas flow, but have a pronounced hump in the middle):
      In this pic I started (from top right to bottom left) with it set to the middle of the 1/8" range (it's 1/8" wall box), then tried it at the top of the 1/8" setting, then finally at the 3/16" setting (you can see it burned through at the end). I have good penetration, doesn't seem to be the lack of surface prep (that piece only has a few rust spots on it, it's nowhere near as bad as it looks in the pic, I cut a weld apart and it's not porous...), it just sits high like that. I'm hoping that I'm doing something wrong because if not that kind of thing pretty much makes the autoset useless (FWIW, I've made exactly the same part before with the HH135 and have no problem laying down a nice flat bead, even with the settings off I can adjust with gun travel...)
    • I think the flow meter might be wonky- I'm used to setting it somewhere _slightly_ higher (one or 2 ticks) than I need, pulling the trigger and getting exactly the gas flow that I need. this one, with a full, new bottle (that is reading the correct pressure...) with it set to maybe 21-22- pull the trigger and it drops to 11 (on my other flow meters i think I'd normally see about 17-18), and when I let go it doesn't always come back to the original setting. Weirder for me, if I close the bottle valve and quickly pull the trigger it will jump past 30 when I let go, and if I do it a couple of times will come pretty close to pegging the flow gauge before it it finally drops from the bottle being closed. Anyone see anything like that before?
    Mark
    (aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp...)
    Synchrowave 180 SD | MillerMatic 211MVP + Spoolmate | Hobart Handler 135 | Everlast Power Plasma 50
    1960 Bridgeport J-head | Grizzly 10x22 | HF bandsaw | Rigid 4.5” angle grinder (+2 cheapie HF ones)
    BFH
    alabama
    750
    It appears you are dragging the puddle, if so try pushing.
    2, XMT's 350 cc/cv
    1, BOBCAT 250
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
    Aug 2009
    Ocala Fl.
    47
    On my 211 the autoset has a mind of its own at times, it works better on 14 and 16ga. metal. It will just take time working with it, and there are some guys on here that just will not use the auotset it is just a pain in the butt..
    May 2011
    Bossier Parish La.
    559
    Forget the auto-set and set it manually, and see what you get. If need be, try the flow-meter from the Hobart on it to see if that helps with the sheilding gas prob.
    Auto Set sucks. I have a 211 and didn't use the feature after 5 minutes. Play with the settings, push the puddle, less wfs, gun angle is too extreme, and a bit slow. Better to lay a bead in a fillett joint vs flat as well. You can't compare beads from a 135 with the 211 either. Always "crack the valve" on the tank before hooking up a new bottle too, possibly clogged, doesn't take much. Hope you figure it out its a great machine!!
    Jun 2012
    Tracy, CA
    221
    I only use the auto set on 3/16" and 1/4" stuff. Otherwise it lays down too much wire.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™ (Sold)
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Yep, use the chart and manual settings. On mine if I use AutoSet it runs way too hot and burns right through the work piece. I get pretty much what you are seeing using AutoSet and it's because my travel speed is to high. Can't be helped because slowing down burns right through. And I'm talking 1/8 to 3/16 materials.
    This is exactly why I think Miller should release a chart or spreadsheet formula for us 211 owners so we can set voltage and IPM better when not using AutoSet. AutoSet sucks and the increments on the dial don't really tell us what we need to know.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    Quote Originally Posted by Great White TJ View Post
    Quote Originally Posted by kvwall View Post
    Quote Originally Posted by Thrutraffic View Post
    LOL, I find it more than a little funny that all 3 of you seem to indicate that it works or doesn't work in different ranges. I guess at least I'm not the only one.
    I would say that a quick guess on my HH135 and 95% of the time I can adjust with travel speed/weave, where the autoset setting isn't close enough for me to do that makes it a totally worthless feature. I'm betting it's programmed somehow into the hardware, I wonder if you can reprogram it.
    Quote Originally Posted by fabricator View Post
    Quote Originally Posted by Packers To Super Bowl !! View Post
    huh... I find it a little disconcerting that both of you think I'm dragging the puddle. I was pushing, probably at about 5-7* from perpendicular to the work piece, so I doubt to extreme either (extreme gun angle pushing usually results in a lot of splatter, I got literally _none_ which did really impress me)
    Why can't I compare beads between the 2. I understand that they're different welders and will have a different feel, but this is that this is just wrong.
    Cracked the bottle, attached the regulator/guages, cracked it again, attached the hose, cracked it again, attached the hose to the back of the welder... I think I flushed the lines out about as well as they're going to get
    Besides the problems listed so far I'm pretty impressed... with the HH135 I always felt like I had to work the weld in there, like I never had quite enough power to really get it fully whetted. I'm not sure that I could do anything to get that welder to burn through on something 1/8" or thicker.
    This thing felt like a proper tool, like it had power to spare and the arc would do what I wanted it to do, it's just the auto set settings were wrong.
    Mark
    BFH
    857
    I'd give the 14ga dial range a try. I haven't had an opportunity to try an auto-set unit, but I suspect input voltage influences the accuracy of Auto-set dial settings. Meaning if Miller designed the Auto-set feature around a 230 volt input, and your supply is 240V or higher, the Auto-set dial setting could be hotter then advertised.
    Also keep in mind that different joint designs require different output power levels. For example, a butt joint constructed out of 1/8" is going to require a lower voltage and wire speed setting then a T joint.
    What type of oscillation if any were you using?
    Dec 2012
    62
    ...Miller should release a chart or spreadsheet formula for us 211 owners so we can set voltage and IPM...
    The chart is in the owner's manual; both the paper version, and the PDF. 4 pages' worth, IIRC.
