Results 1 to 10 of 10
    Default Rusty pipe flange. Need to separate
    I'm trying to redo the pipe on my exhaust for my truck. In order to take only the section off I need welded, there's a flange right after the catalytic converter that I should be able to unbolt. Only problem is it is so rusted that I can't get it to come apart. Any ideas?
    Nov 2012
    Northern Arizona
    269
    Pb blaster or wd40 and let it sit? How fast does it need to come off? Can you heat up some part of it to break it loose?
    MillerMatic 251
    CST 280 w/tig torch
    HF-251-D1
    Cutmaster 42
    Victor Journeyman OA
    Jul 2011
    N. Mississippi
    7
    BFH---works every time.
    Jul 2010
    335
    Heat wrench...BFH...hacksaw...O/A torch
    1,569
    If your just talking about the bolts then get new ones & cut off the old ones. If you have already done that & the flanges still won't seperate then you can try heating them with a torch & hitting with a hammer. Also maybe there is a spot you can get a chisel started between the flanges to force them apart.
    Ok. I think I'm gonna try the chisel since I cut the bolts and it's still attached. I don't really have access to a hot enough torch so thats out the window.
    Clarksville, TN
    427
    If inner pipe is trash denting it inwards will help breaking the rust. Heat from a propane torch would be a big help. Either way wd-40 and tapping it with a hammer will help too. If you spray it before heating it watch you eyebrows.
    Hampton, Va.
    384
    Kroil
    Jan 2012
    Metro Detroit, MI
    182
    Default Get tools
    Invest in some Kroil Oil and O&A torch. Do you have an air hammer? cut off a bit or buy a hammer bit and vibrate it off
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Aug 2008
    103
    I do lot of custom exhaust work please post what year model motor and ect ect ect i can tell you a easy way to fix it u might not need to worrie about the flange behind the cat post it up and will advise
