Results 1 to 4 of 4
    Default Can I hookk up 6038LR wire feeder to
    this machine costs $1200
    I'm wondering if I can cobble up something similar for half the cost?
    the feed pen costs $125
    http://www.arc-zone.com/index.php?ma...oducts_id=7904
    Looks like the feed pen has a cigarette 12v power supply and some sort of data cable to feed the spool wire.
    are there any miller wire feeders that would work with this feed pen? if not are there any that could be modified relatively easily?
    I saw this wire feeder on ebay, but a search on it here yielded no results
    http://www.ebay.com/itm/MILLER-ELECT...item2ec4bc46ff
    i have only tig welded so I am unfamilar with mig gear. will be used to weld 16gauge aluminum with Lincoln PT-275 machine.
    just looking to speed up production.
    Default electrical schematic
    here is electrical schematic. the data connection is a r2 plug. any help is appreciated
    you can download the entire user manual here:
    http://profaxlenco.com/images/Manual/Manuals/07200.pdf
    Mar 2008
    Dallas,Tx
    172
    Default Feeding Aluminum
    Is your goal to mig weld aluminum or to tig it? The Miller feeder in your post is the control mechanism for an S60M feeder meant to feed wire in the mig process. The Profax feeder is very slow speed meant to feed wire into a tig puddle. If it is tig welding you are after, there are several used cold wire feeders out there for half the amount you mentioned. weldersales
    Default please tell me manufactuer and model # of these used tig feeders for less than $600
    "there are several used cold wire feeders out there for half the amount you mentioned"
    OK you've got my attention, what are the names of these used cold tig feeders that are less than $600??? i searhced the forum, web and ebay with no luck.
