Hey how's it going I have a simple question that came up between me and a friend. Dose a foot pedal give you the same amperage control on lift start as it would on Hf-start on a XMT machine.
Results 1 to 8 of 8
Thread: simple Tig question
12-24-2012, 06:45 AM #1
Member
- Feb 2011
- 53
simple Tig question
12-24-2012, 07:17 AM #2
- Jul 2008
- East Tennessee
- 609
A xmt doesn't have high frequency unless you've added a external high frequency box such as a hf-251. The amperage would be the same.
Dynasty 200DX "Blue Lightning"
Bernard 3500ss water-cooler
Rockwell vertical mill
Beverly Shear B-3
Beverly Shear JR
Home-made English wheel
Milwaukee Porta-band
" Sawz-all
Tennsmith 36" stomp shear
Fixer upper 1982 Lincoln sa200
12-24-2012, 07:51 AM #3
Member
- Feb 2011
- 53
simple Tig question
The question is about amperage control I am aware there is no Hf on this machine
12-24-2012, 08:08 AM #4
I interpreted the question the same way Showdog75 did. It seemed as if you were comparing the foot control in HF and LA on an XMT.
The foot control should function the same on LA or HF on any electric machine. I mainly use Miller machines so I can't say much as far as lincoln machines go, but I am sure they work the same.
If the XMT has auto remote sense, it would for sure be the same.
12-24-2012, 08:10 AM #5
- Oct 2007
- Cave Creek Az
- 803
12-24-2012, 08:21 AM #6
Member
- Feb 2011
- 53
simple Tig question
Ok maybe I worded that poorly. Dose the foot pedal amperage control function properly in lift start Tig welding. High freq. is only mentioned as reference. Or better yet. Can you still use a foot pedal if you don't have HF.
12-24-2012, 08:26 AM #7
- Apr 2009
- Upstate SC
- 130
Foot control controls amps, regardless of how you start.
CGOld Miller Swinger 180 Buzzbox
Miller Diversion 165
Smithy Lathe/Mill
12-24-2012, 08:33 AM #8
Member
- Feb 2011
- 53
simple Tig question
Thanks that's what I was looking for CG
