Are tanks marked to indentify that you own them?
So if you are exchanging your personally owned cylinders for full ones each time, what if you were to quit using that supplier and decided to use another supplier or simply decided not to get your tank filled there anymore. Would you just keep the tank and take it to the other supplier no questions asked?
Or would you have to tell your current supplier your going else where first and they would have to give you a different tank with an identifier that you own it?
How would the other supplier know that you brought in a cylinder you owned and were not exchanging a rented cylinder from another company?
Results 21 to 23 of 23
Thread: Owner Owned argon Cylinder!
01-10-2013, 04:40 PM #21
- Dec 2012
- Sweetwater, TX
- 194
01-10-2013, 05:05 PM #22
- Dec 2011
- 230
Transporting Acetylene
The idea of keeping the tank vertical is to keep the liquid acetone in the tank, one issue. And secondly out of your regulators. I don't know if it is true but I've been told that it will wreak havoc with your regulators. I don't plan to test the theory. More importantly, acetylene is unstable at the pressure in the tank so it is dissolved in acetone to keep it stable. I guess if you were to partially empty the tank it could be very dangerous. I don't intend to test that theory either. So if you lay one down let it stand upright long enough for the acetone to fully drain down from the valve. Acetone is very fluid so I guess 10 minutes is likely safe. When you are transporting make sure all tanks are well secured and cannot slide around or forward or backward. Besides being dangerous it will also get you a hefty fine if the DOT sees you.
Meltedmetal
01-10-2013, 06:07 PM #23
Thats where you need to call your local welding guy and talk to them. Everyplace has different "laws" that pertain to cylinders. I own some that i have a paper for from my local guy. So one day i asked him if i sell my business what about the tanks. He said good luck with them esp if they go out of state since they are all marked with his company name but say sold stamped on them and maybe someone will fill them and maybe they won't. So its best to ask where you will be getting bottles from because everything else is just a crap shoot. Some you win and some you loose...Bob
