    Jun 2012
    Tracy, CA
    221
    Default Tig Weld Parts Needed - Trailblazer 302
    I want to start using my TB302 for Tig welding steel and aluminum.
    What parts will I need? Obviously I need the torch. I'm looking for a 25' setup if not a bit more. I'd like to get a nice torch with a shorty/rotating head.
    Thanks all. Happy Holidays.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™ (Sold)
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    8,209
    Visit you LWS, get a tig block, a torch of your choice with a gas Valve, a HF Arc stabiizer if your going to run Aluminum, a peddle if you need arc control. Argon for steel and Aluminum, Trimix for stainless
    Aug 2008
    Orange, TX
    1,216
    Trimix? TIG? Any CO2 (part of trimix) with TIG is a definate no no. 100% argon all the way.
    Trimix with MIG for SS - yes.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Dec 2009
    Detroit
    37
    Quote Originally Posted by duaneb55 View Post
    +1 on 100% argon. Could add a helium bottle to your rig...a little more umph for tiggin aluminum.
    Jun 2012
    Tracy, CA
    221
    Thanks guys. Does that peddle have a cable? Or will it be remote to the 14 pin connector some how?
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Nov 2012
    Spencer, MA
    7
    Quote Originally Posted by kvwall View Post
    You can choose wired or wireless foot/hand/finger controls, with various pin configurations. The TB302 I believe has a 14 pin remote plug like my TB325, check your owners manual for conformation to be sure.
    Miller has a good selection but there are a few other manufactures that seem to provide a quality products I've found so far.
    Here's Millers link for remote controls.
    http://www.millerwelds.com/products/...mote_controls/
