Results 11 to 15 of 15
    Aug 2008
    Orange, TX
    1,215
    . . . and bottle of Argon, or trimix.
    And as pointed out in the other thread - no trimix for SS with TIG - 100% argon only. TIG and CO2 (in trimix) do not go together.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Nov 2012
    Spencer, MA
    7
    Joshua, Take a look on that other post, I left a fairly detailed set up to help you get started on tig welding, I will recheck back here in a couple of days to see if you have any more questions. But take a look at the other fellas post.
    I think you're referring to this thread, TIG-unit-question, Post #12 correct?
    Thanks for the info, keep it coming.
    Quote Originally Posted by duaneb55 View Post
    Noted on the Argon.
    Aug 2004
    Milan Michigan
    1,776
    Yes Joshua, Post #12, I hope that gave you some of the imformation that you needed.
    8,020
    Have tri-mix on the brain, was thinking Argon-Helium, have a bottle of it here. Welds stainless slick
    La Porte, Tx.
    56
    Personally I like the tweco 150 amp flex head torch, but I think they've gone out of business or sold out, all we used in the furnaces was the tweco, man their tough,, the power cable use to be called "super flex" one piece,, two piece (two hoses, one power one gas) equals junk in my book.
    I have trailblazer also for home use, good generator, I bought the add on HF box just like we use at work for my aluminum work, can't remember the model # though but it's very durable, I also use a 1/8" tungsten set up for 95% of my tig work even at work.
    If I remember right the contractors that weld next to me at work use the Weldcraft torch,, never really cared for them, just wouldn't take the abuse, maybe its changed, but my Tweco set up has served me well for the last 20 yrs.
    pull-do
