Results 11 to 15 of 15
Thread: Tig setup for a Trailblazer 325?
12-24-2012, 09:03 AM #11
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
12-24-2012, 01:17 PM #12
I think you're referring to this thread, TIG-unit-question, Post #12 correct?
Thanks for the info, keep it coming.
Noted on the Argon.
12-26-2012, 03:03 PM #13
Yes Joshua, Post #12, I hope that gave you some of the imformation that you needed.
12-28-2012, 07:08 AM #14
Have tri-mix on the brain, was thinking Argon-Helium, have a bottle of it here. Welds stainless slick
12-29-2012, 10:18 AM #15
Member
- Mar 2006
- La Porte, Tx.
- 56
Personally I like the tweco 150 amp flex head torch, but I think they've gone out of business or sold out, all we used in the furnaces was the tweco, man their tough,, the power cable use to be called "super flex" one piece,, two piece (two hoses, one power one gas) equals junk in my book.
I have trailblazer also for home use, good generator, I bought the add on HF box just like we use at work for my aluminum work, can't remember the model # though but it's very durable, I also use a 1/8" tungsten set up for 95% of my tig work even at work.
If I remember right the contractors that weld next to me at work use the Weldcraft torch,, never really cared for them, just wouldn't take the abuse, maybe its changed, but my Tweco set up has served me well for the last 20 yrs.pull-do
