Results 1 to 4 of 4
Thread: difference
    Aug 2006
    Raymore Missouri
    1,925
    Default difference
    Can anyone tell me the difference between R4043 tig rod and ER4043 for aluminum? . I looked and had no good luck.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Nov 2012
    Spencer, MA
    7
    The nearest I can come to answering your question is that the Prefix "ER/R" on ER4043 refers to.
    E = Electrode
    R = Rod
    ER = Electrode & Rod
    Alloy designation 4043 Aluminum
    ER4043
    Page 42 describes it more in depth than that.
    http://www.millerwelds.com/resources...Book_Chpt4.pdf
    Dec 2012
    Piedmont Triad
    8
    Good question. Might just be different manufacturer prefixing????
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    In all cases an electrode that meets the test prescribed in A5.10 AWS specification can be used either as an electrode or a welding rod, but the reverse is not always
    true for a “R” classification aluminum “rod.” Hope that helps.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
