Went to do some tig welding on a pocket knife for a neighbor. Remote contactor worked one time and quitChecked the plug on the pedal and it is working . Any suggestions ? I am pretty sure its a 1977 model .
Results 1 to 7 of 7
12-19-2012, 06:05 PM #1
- Jul 2010
- 8
Dialarc HF remote contactor not working.
12-19-2012, 07:53 PM #2
No Serial#, no can help......
12-19-2012, 08:04 PM #3
- Jul 2010
- 8
Hh012516
12-20-2012, 08:09 AM #4
If the microswitch in the pedal is ok, you likely have a stuck CR3 relay in the machine. There are 3 relays, CR3 is the one furthest away from the square bridge. Give it a tap with a screw driver end, or replace it.
12-20-2012, 09:30 PM #5
- Jul 2010
- 8
Thanks. I will check it out.
12-24-2012, 06:52 AM #6
- Jul 2010
- 8
I tried tapping on the relay while stepping on the pedal and it still did not want to close on its own. I found a new relay on ebay and bought it. Looks like they are hard to come by. ????
01-12-2013, 04:49 PM #7
- Jul 2010
- 8
Thank You cruizer
$25.00 fix
