Results 11 to 17 of 17
Thread: Finally made the decision
12-20-2012, 12:27 PM #11
- Dec 2012
- Sweetwater, TX
- 194
12-20-2012, 12:32 PM #12
- Dec 2012
- Sweetwater, TX
- 194
I would have thought being capable of 200amps that it could weld thicker than 1/4", especially if Country Metals is welding 1/2" steel.
So even welding 1/4" steel 3 or 4 minutes and then giving the machine a break while fitting up stuff is going to be to hard on the machine?
Would the machine handle it any better in stick mode versus tig mode?
Thanks,
Clint
12-20-2012, 12:45 PM #13
- Nov 2012
- Northern Arizona
- 269
I don't see why you couldn't bevel and run a couple passes to exceed the 1/4" rating.
MillerMatic 251
CST 280 w/tig torch
HF-251-D1
Cutmaster 42
Victor Journeyman OA
12-20-2012, 01:57 PM #14
Wohhhh,Wohhhh,Wohhhh,Wohhhh, Wohhhh.... Slow down......
I never said that I was welding 1/2" in one pass. You can use a 110 stick welder to weld the entire hull of a nuclear submarine, AS LONG AS you know how to do it. Preheat, rod size, between pass temps, a lot of experience, ect, and a lot of time on your hands.
For clarification, the specs that miller provides are for 1 pass only, not multi pass welding or usage of preheat. I would call it, fabricating specs because most welds in fabrication are single pass. Not pipe specs, military, structural, ect.
As far as AC, I do weld with it at 200 amps, I don't do it enough to really notice a difference. I only weld aluminum about once every 2 weeks at best. Usually only 1/8 - 3/16". Also running helium mix/straight will allow more heat to transfer and allowing you to run less amps meaning more duty cycle. But more cost in gas.
I just got done putting new teeth on a pulverizer and some 1 1/2" thick wear plates on bottom. I used the 200 DX to put 5/32 11018 first 3 passes in on the wear plates and then dual shielded the rest with my Invision 352 MPA Plus. I just like that strong stick beginning. I did have to preheat and move a lot to keep heat at a reasonable level.
Overall I like my 200DX
12-21-2012, 07:56 AM #15
- Dec 2012
- Sweetwater, TX
- 194
Hi Country Metals, So you do use your Dynasty 200DX for both AC tig and DC Stick it appears. Any problems with the machine as a result of switching back and forth?
Did you use the "dig" features on the 200DX when welding that 11018 rod? Do you think the feature is an improvement over the old transformer based welders that lack the feature?
I have never heard of 11018 rod, but it looks like it takes the same amps as 7018 to run, so maybe this machine will be able to take all I can throw at it using 1/8 7018 and 5/32 6010 rods.
The Dynasty 200DX would definetly be ideal for me on the tig side, but I just want to know if the stick side of the machine can keep up with the best of them like maybe the CST 280 and the dialarcs.Last edited by clint738; 12-21-2012 at 07:57 AM. Reason: spelling
12-21-2012, 08:56 AM #16
Gotta say I have murderized my Dynasty200, fried a weldcraft wp17, tectorch wp17, and never tripped the thermal overload. Of course the torch was smokeing and I put it down long before I would consider damage was done to the machine itself.
In fact I have never tripped the thermal overload on any of my other dynastys either.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
12-21-2012, 01:31 PM #17
I would only need a Dynasty 200 DX and a MM 350P to live the rest of my days out as a welder. Period!
