Results 1 to 10 of 15
    Riverside, CA
    3
    Default Best Welder for my situation?
    I was wondering what would be the best Miller Tig welder I could get for my particular situation? The power input for the welder would be a single phase 220v circuit with a 50 amp breaker. I have a budget of $5000.00. Is this more money than I need to spend for a welder that will match up with the power I have to offer it? Does it pay to have a unit with a water cooler? Inverter model? I will probably be welding equal amounts of stainless steel, mild steel, and aluminum. I would like a machine that has the fewest limitations for the money and power I have. I have alot of experience MIG welding and limited experience with Arc welding and brazing.
    I have never TIG welded before and am aware of the diffuculty, but know I would like to start out with a high quality unit. I have read many of the articles on the Miller web-site, but would love to have some feed-back from the people who are out there using these products, as well as some Miller tech feedback if possible.
    Thanks,
    Matt
    Fallbrook CA
    20
    Matt you didn't say what your requirements were for thickness etc but... as a general statement would tell you the Dynasty 200 DX is a hard act to follow; also well within your budget. I started out with a syncrowave SD180 and it's a fine machine but upgraded when the road show came to town and I had a chance to try a Dynasty 200 DX and to see what some of the real good welders could do with it. Lots of advantages to it. If you go over to the Hobart site you will find lots of good comments on it. By the way If your anywhere near me you could come by and try out the syncrowave 180 and the dynasty 200DX to get a good comparison. The next step up the power ladder would be a Dynasty 300 DX but equipped to use would be straining your stated budget.
    Plymouth, MI
    475
    Matt,
    A Dynasty 200DX with a Coolmate 3 and a watercooled torch would be a great setup. You need to get a foot or fingertip control (I'd recommend the foot controller) and a water-cooled torch (a #20 with the superflex hoses from TIG Depot witht the correct connectors for the Dynasty) You would also need to get tungsten (1.5% lanthanated) and a tank of argon shielding gas (get as large a tank as you can easily handle). I ended up getting two 80cf tanks.
    Bob Sigmon
    ___________________
    Dynasty 200DX w/ Coolmate 3
    Miller Passport
    LMSW-52T Spot Welder
    A/O Setup with Meco Midget
    Miller Big Window Elite
    Quincy QT-5HD
    Sep 2002
    Clark County, NV
    2,696
    I agree with the Dynasty 200DX. You'll have plenty of the budget left over for the Coolmate 3, and some NICE torches, cables, steel to build a cart with, Miller Big Window Elite autohood, and anything else you'll need that you don't already have.
    Riverside, CA
    3
    Thanks for the info guys. Im definetly looking at the 200DX but considering saving for a little while longer to get the 300DX. Harold, I actually live not far from you and drive by there everyday to go to work. Would love the chance to try the 200DX before I buy it. Thanks, again!
    Sep 2002
    Clark County, NV
    2,696
    If not too much more saving would be involved, I would definitely opt for the Dynasty 300DX Tigrunner with the Coolmate already to go in a nice cart and everything. It's a $5700 package with torches and everything except the gas.
    563
    Matt,
    I agree with Bob and Mac.The 200DX is a real good machine but I would hold out just a little longer and get the 300DX.I don`t think you`ll regret the wait.
    Fallbrook CA
    20
    Matt let me know when you would like to stop by and I'll e-mail you directions on how to get here. Almost any day but sundays, that's our church day and usually gone for the duration.
    Harold
    Evansville, IN
    2,348
    I love my D200DX, but if the cash is available for the Dynasty 300DX---DO IT! That is the greatest tig I've every used, I've welded down to 4 amps on .005 aluminum and up to 300 amps fixing cracked castings with one at the university. It is a drop everything else machine. A friend of mine used my 200DX and his shop now has a 300DX sitting on top of a sync 250 that doesn't even get turned on.
    Weld well
    Champlin MN
    37
    is the synchrowave 250 a bad machine, or is the dyansty 300 just that much better and more advanced?
