Results 11 to 14 of 14
    Feb 2010
    YOUNGSTOWN, OHIO
    127
    Quote Originally Posted by Stu Miles View Post
    If machine only does 1/8 inch penetration on aluminum,
    and lets say I am welding 1/4 inch aluminum plate.
    I do one side and flip it over -
    is that doing the same thing as one pass with a machine rated for 1/4 inch alum ?
    Thanks, Stu
    I am curious as to what machine you are thinking gets 1/8 inch penetration on aluminum cause for $1000 you are not going to get a machine that even comes close to that.
    And when the size of a fillet weld is measured, it is measured from the leg to the toe and the effective throat is what actually means anything.
    I think you may be misunderstanding the ratings for these machines. When they say 1/4 inch, that means that is the max. thickness of base metal for a single pass weld.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Dec 2012
    27
    Default Your advice is helping my decision
    What machine are you looking at? If you are looking at a 110 mig for aluminum don't waste your time. If the machine is rated for 1/8" steel it will not do 1/8" aluminum very well. Judging by your $1000 budget you are looking at something bigger?
    The advice here is a big help.
    I'm see I need to spend more for machine that can plug into 220 for better penitration.
    And this characterization makes me understand better -
    "So it's almost like a race where you're "chasing the heat." To weld aluminum, you need a machine with enough power to dump enough heat into the puddle faster than it can "leak out" into the surrounding metal."
    So guess I will save a little more money and go for the passport,
    I'll get a 220 plug into the garage. It's other attributes serve my needs.
    The stuff I want to do is not really weight bearing and will not have much stress on it. Just making armatures out of 1/4 " bar. I'll start on steel but would like to try aluminum at some point.
    Thanks for the help,
    Stu
    Wa
    316
    If these things are not going to be holding hardly any weight you are over thinking this. You are doing a simple butt joint it sounds like, just bevel the weld surfaces and weld them up. Or just take the parts to a local welder and have them weld the pieces you need, it would not cost much.
    Dec 2012
    27
    Default simple butt joint
    Ya I guess that's the thing - I 'm on a forum where most of the folks
    really do welding for specific heavy duty needs.
    My stuff is more hobby related - I attached a photo here of what I am wanting to do - but with aluminum as well as steel.
    They will be simple butt joints with 1/4 inch bar.
    But I do want to get into aluminum at some point.
    If anyone can point me to a tutorial video of a miller passport plus
    doing aluminum would appreciate. Can't find any on you tube.
    Thanks, Stu
