Results 1 to 7 of 7
Thread: Need a tip...
    Apr 2011
    306
    Default Need a tip...
    I broke out the welder over the weekend to build a mount for my rotating light.
    Long story short, first I completely suck as the regulars on here already know.
    And second, how do you weld a half inch rod to a plate, and better yet when you can't get all the way around at once because there are 3 "legs?"
    I got it done but it seems like I did it the hard way.
    Just For Home Projects.
    Aug 2006
    Raymore Missouri
    1,906
    Any pictures......a half inch rod can be welded to a plate in numerous ways.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Apr 2011
    306
    Default Too embarassed...
    No pictures...I was basically looking for a tip on how to weld around it.
    I will take some and post up when I get home tonight...It is already primed.
    In hind sight I should have drilled the plate and plug welded it to start but was being lazy as it didn't need to be precise...
    I did ok even if there is way more weld on them than needed.
    Nov 2012
    Northern Arizona
    269
    Is the rod laying across the plate so that there is an acute angle to fill between the plate and the rod? If you look at it from a cross section it is like a car tire on the ground with a small contact patch?
    Apr 2011
    306
    Default Nope...
    I know how to weld along something, I just don't have the skill set to weld around something in a tight spot.
    photo.jpg.
    I didn't care about the splater and didn't notice the "tail" before I painted...it was late, I was just trying to get it done...poorly I guess.
    Jan 2012
    Metro Detroit, MI
    182
    That's isn't the worst weld I have ever seen. You sure aren't going to win any beauty awards. I guess the only way to MIG weld it is get good position, tack weld in a few spots, hold the torch at an angle that it can be manipulated in a 360 degree motion without changing the angle and stick-out to drastically and weld. I like to do things like rod and rebar in cursive E's like overhead because I can just work my way around consistently and ending the last E one against my first E letting my puddle merge so my weld looks consistent. I think that's the best way I can explain how I do it. I hope that someone gets something out of that or i just told you stuff you already k ow or do and I'm a retard.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Apr 2011
    306
    Default Just looking to get better...
    I had too many starts and stops for my liking...and too much weld in some and not enough in other spots. But they are now joined as one.
