I broke out the welder over the weekend to build a mount for my rotating light.
Long story short, first I completely suck as the regulars on here already know.
And second, how do you weld a half inch rod to a plate, and better yet when you can't get all the way around at once because there are 3 "legs?"
I got it done but it seems like I did it the hard way.
Results 1 to 7 of 7
Thread: Need a tip...
12-17-2012, 10:37 AM #1
- Apr 2011
- 306
Need a tip...
Just For Home Projects.
12-17-2012, 10:48 AM #2
Any pictures......a half inch rod can be welded to a plate in numerous ways.
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
12-17-2012, 02:19 PM #3
- Apr 2011
- 306
Too embarassed...
No pictures...I was basically looking for a tip on how to weld around it.
I will take some and post up when I get home tonight...It is already primed.
In hind sight I should have drilled the plate and plug welded it to start but was being lazy as it didn't need to be precise...
I did ok even if there is way more weld on them than needed.MillerMatic 211 Auto-set w/MVP
12-17-2012, 04:22 PM #4
- Nov 2012
- Northern Arizona
- 269
Is the rod laying across the plate so that there is an acute angle to fill between the plate and the rod? If you look at it from a cross section it is like a car tire on the ground with a small contact patch?
12-18-2012, 02:10 PM #5
- Apr 2011
- 306
Nope...
I know how to weld along something, I just don't have the skill set to weld around something in a tight spot.
photo.jpg.
I didn't care about the splater and didn't notice the "tail" before I painted...it was late, I was just trying to get it done...poorly I guess.Last edited by Doughboyracer; 12-18-2012 at 02:15 PM.
12-18-2012, 03:45 PM #6
Need a tip...
That's isn't the worst weld I have ever seen. You sure aren't going to win any beauty awards. I guess the only way to MIG weld it is get good position, tack weld in a few spots, hold the torch at an angle that it can be manipulated in a 360 degree motion without changing the angle and stick-out to drastically and weld. I like to do things like rod and rebar in cursive E's like overhead because I can just work my way around consistently and ending the last E one against my first E letting my puddle merge so my weld looks consistent. I think that's the best way I can explain how I do it. I hope that someone gets something out of that or i just told you stuff you already k ow or do and I'm a retard.
Never Satisfied
Millermatic 211
Maxstar 150STL
Metabos
Kennedy Maintenance Pro Full
Makita Cordless 18v Li-Ion
Stihl TS 420
Timfrank88@live.com
12-18-2012, 03:49 PM #7
- Apr 2011
- 306
Just looking to get better...
I had too many starts and stops for my liking...and too much weld in some and not enough in other spots. But they are now joined as one.
