Results 1 to 3 of 3
    Nov 2012
    Default miller 225 g wont fast idle
    hello, i have a 225 g with the onan performer engine. carb was full of dirt and crud. rebuilt with new parts. runs fine now but will not rev up for welding power. if i push throttle back it runs full speed but governer wants to pull back to idle. any ideas? thanks!
    8,104
    Again, can't do much without a serial#
    Oswego IL
    723
    Default throttle solenoid
    The govenor is suppose to pull the throttle back. Does the electric solenoid fot the throttle work?
    XMT 304
    Miller Spectrum 625
    Miller 30a spool gun
    S22a
    Miller Legend 302
    Lincoln LN25
