Would like some advice on preheating aluminum bar.
Tack welding 1/4 inch aluminum bar for tack weld at T joint.
How would I preheat for mig welding with a passport plus using spool gun
an argon.
Anyone have experience welding aluminum bar with mig ?
Results 1 to 10 of 11
Hybrid View
12-16-2012, 12:51 PM #1
- Dec 2012
- 27
Please help - how do you preheat aluminum for mig ?????
12-16-2012, 01:08 PM #2
That thin you really don't need a preheat just turn it up and go.
12-16-2012, 01:20 PM #3
12-16-2012, 01:33 PM #4
- Dec 2012
- 27
Hi Bob
Hi Bob
I guess I should have asked first -
Do I need to preheat the 1/4 inch aluminum bar ?
using passportplus/spoolgun/110.
I've been told it's not possible as it will be too cold,
then told it would melt too fast.
Thanks for reply,
Stu
12-16-2012, 01:50 PM #5
Don't know about your passport as i have never used one but you will just have to try a couple of small chunks of what you will be doing. That would be the best way. Just my thoughts...Bob
12-17-2012, 06:19 AM #6
Even with heat, you are pushing the passport at 110. It all depends on how practice pieces work out.
12-17-2012, 03:53 PM #7
I had to weld 7" x 7" x 8' chunks of aluminum to 4x4x1/4" TS and used a propane rose bud and a temp stick, I brought it up to 450 degrees before welding it with my push pull set up.
12-17-2012, 09:10 PM #8
- Sep 2012
- 7
Make sure if you are preheating or welding to insulate it, if you are welding on a steel table, the steel really sucks the heat out of aluminum and makes it difficult to weld
12-18-2012, 09:09 PM #9
- Dec 2012
- 27
Thank you
Thanks - the advice and tips here are really helpful,
appreciate your time replying.
Stu
