Results 1 to 10 of 11
    Dec 2012
    27
    Default Please help - how do you preheat aluminum for mig ?????
    Would like some advice on preheating aluminum bar.
    Tack welding 1/4 inch aluminum bar for tack weld at T joint.
    How would I preheat for mig welding with a passport plus using spool gun
    an argon.
    Anyone have experience welding aluminum bar with mig ?
    May 2012
    chilliwack BC
    38
    That thin you really don't need a preheat just turn it up and go.
    3,953
    Quote Originally Posted by Stu Miles View Post
    35 years worth. I use a propane torch...Bob
    Dec 2012
    27
    Default Hi Bob
    Hi Bob
    I guess I should have asked first -
    Do I need to preheat the 1/4 inch aluminum bar ?
    using passportplus/spoolgun/110.
    I've been told it's not possible as it will be too cold,
    then told it would melt too fast.
    Thanks for reply,
    Stu
    3,953
    Don't know about your passport as i have never used one but you will just have to try a couple of small chunks of what you will be doing. That would be the best way. Just my thoughts...Bob
    Jul 2010
    Salem, NJ
    294
    Even with heat, you are pushing the passport at 110. It all depends on how practice pieces work out.
    Aug 2004
    Milan Michigan
    1,837
    I had to weld 7" x 7" x 8' chunks of aluminum to 4x4x1/4" TS and used a propane rose bud and a temp stick, I brought it up to 450 degrees before welding it with my push pull set up.
    Lake of the Ozarks MO
    3,594
    Try a test piece first. If the bead profile is too high, then preheat and try it.
    Some things need preheat just to get the bead to flow out decent.
    I like to use the AO torch and smoke it (with the soot) myself. Then heat until smoke is gone. Works good for me.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Nov 2009
    Mapp gas burns hotter. Costs more but works better.
    Make sure if you are preheating or welding to insulate it, if you are welding on a steel table, the steel really sucks the heat out of aluminum and makes it difficult to weld
