Results 1 to 4 of 4
Hybrid View
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Question How about it. Can anyone give some input on this?????
    I was looking at a 2005 model 350P with about 300 hours on it and I'm assuming 10,004 arc strikes on it.(It was only registering 4 so I assumed it turned over). Again, assuming that it was not used in a heavy plate fab shop being ran near max every day, what are the hour and arc strike " magic numbers" when you should just not even consider the machine and walk away from it?
    By the way, I could probably get the machine for about $1,400.00.
    Also, when you would turn it on and it would power up, it would buzz very, very loudly. Much louder than the new 350P that I have. Is that an indicator of something???
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Hey Cruizer, got any input on this? You have probably seen a few.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Oct 2004
    Edmonton, Alberta
    8,325
    Nice units, based on the XMT304, your buzzing / chattering has to do with a failed contactor. Not a big deal nor expensive to change out. (-$40) just REMEMBER the positions of all the wiring on it, cause if you get the auxillary winding wires wrong, the machine's output board goes poof.
    $1400 isn't bad either, you could probably tell the guy that the loud buzzing could be a bad inverter if the guy doesn't have a clue and get it cheaper.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Thanks Cruizer. That is exactly the info I was lookin for.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
