Results 1 to 6 of 6
    Dec 2012
    1
    Default What is this welding equipment worth?
    I have the following:
    Miller Dynasty DX (KJ171178)
    Miller Dynasty 300DX (KK115418)
    Miller Spectrum 2050 (KJ140832)
    Foot controls
    New TIG Torch
    Used TIG Torch
    2) Rod holders
    2) Grounding clamps
    2) 60 amp plugs
    2) 480v 60 amp quick disconnects with plug in
    1) 480v 60amp quick disconnect
    Stainless filler rods, about 100 lbs (1/8 & 3/16)
    Various fittings for the TIG Torches
    All of the equipment is from an industrial plant and has not been used since shutdown in 2007.
    In 2009 I brought the 300DX in for inspection and repair. (2 power modules replaced, $500)
    This equipment is overkill for my basic needs. I would like to sell it and get something more my speed (Just learning to weld, basic home and garage use)
    4,494
    If its something you already own a 200 dyn would be ideal and the 2050 fits right in, runs from common 50A single service. I wouldnt trade, spend, buy or sell if I had those if I didnt have to.
    Feb 2012
    11
    Default Equipment value
    Value depend on the condition of the machines an the need of the buyer ;but nothing is over killing in welding more you have ,more you can do and better quality,as someone post allready i will also tell you not to sell if dont need or will regret later
    Aug 2008
    113
    Quote Originally Posted by jg1171 View Post
    Foot controls
    New TIG Torch
    Used TIG Torch
    2) Rod holders
    2) Grounding clamps
    2) 60 amp plugs
    these are from 1998 and 1999 there is no point in going down to a 200 dx if u already own dynasty 300 your much better to stick with what u have plus u already know what u got it works and not costing u a dime just sitting there plus u will find u want to weld more then 1/4 inch u will be mad at your self sorry to yack at ya just my two cents
    Apr 2009
    Oswego IL
    796
    Default simple ebay.
    If you dont know value use ebay list the exact name of each welder in the title . List serial numbers and pics in the describtions. Let the auctions run for 7 days.
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
    Aug 2008
    113
    Quote Originally Posted by Tryagn5 View Post
    i have seen them on ebay around 1500 or so for the 2050 and around 3000 to 3500 for the dynasty 300 but thats probably not what there worth cause if it was a deal it would not still be on ebay
