I have the following:
Miller Dynasty DX (KJ171178)
Miller Dynasty 300DX (KK115418)
Miller Spectrum 2050 (KJ140832)
Foot controls
New TIG Torch
Used TIG Torch
2) Rod holders
2) Grounding clamps
2) 60 amp plugs
2) 480v 60 amp quick disconnects with plug in
1) 480v 60amp quick disconnect
Stainless filler rods, about 100 lbs (1/8 & 3/16)
Various fittings for the TIG Torches
All of the equipment is from an industrial plant and has not been used since shutdown in 2007.
In 2009 I brought the 300DX in for inspection and repair. (2 power modules replaced, $500)
This equipment is overkill for my basic needs. I would like to sell it and get something more my speed (Just learning to weld, basic home and garage use)
12-14-2012, 08:05 PM #1
- Dec 2012
- 1
What is this welding equipment worth?
12-15-2012, 02:05 PM #2
- Sep 2005
- 4,247
If its something you already own a 200 dyn would be ideal and the 2050 fits right in, runs from common 50A single service. I wouldnt trade, spend, buy or sell if I had those if I didnt have to.
12-15-2012, 02:45 PM #3
- Feb 2012
- 9
Equipment value
Value depend on the condition of the machines an the need of the buyer ;but nothing is over killing in welding more you have ,more you can do and better quality,as someone post allready i will also tell you not to sell if dont need or will regret later
12-16-2012, 06:43 PM #4
- Aug 2008
- 103
these are from 1998 and 1999 there is no point in going down to a 200 dx if u already own dynasty 300 your much better to stick with what u have plus u already know what u got it works and not costing u a dime just sitting there plus u will find u want to weld more then 1/4 inch u will be mad at your self sorry to yack at ya just my two cents
12-16-2012, 06:50 PM #5
- Apr 2009
- Oswego IL
- 511
simple ebay.
If you dont know value use ebay list the exact name of each welder in the title . List serial numbers and pics in the describtions. Let the auctions run for 7 days.
XMT 304
Miller Spectrum 625
Miller 30a spool gun
S22a
Miller Legend 302
Lincoln LN25
12-16-2012, 07:00 PM #6
- Aug 2008
- 103
