Results 1 to 10 of 10
    Default What can i make with this?
    I have this 3/16" plate that has been cnc'd. my boss was going to scrap it, but i see past the scrap. now i need ideas on what to make....wall art, a tree with leafs, i dunno. i could cut each diamond seperatly, or in sets of 4 or more. please give me some ideas, i love building ornemental, artsy stuff. thank you.
    i was thinking, maybe i could make some kind of sphere out of it. i would have to slightly contour each "diamond" then weld together. not sure what the diameter would be with only 30 pieces.
    cmon guys, any ideas?
    Mar 2011
    19
    Smile
    Quote Originally Posted by westpoint View Post
    how bout a wine rack?
    Jun 2009
    greenfield new hampshire
    783
    i picked up some thing similar to that from the sheet metal shop in my area, i used it in my wifes flower garden, i made a trelace out of it, the vines grow up thru the holes, looks good when it fills in with growth
    Aug 2008
    12
    I'm not a fan by any means, but, it looks like a Steelers Logo waiting to happen.
    Maybe a 12" diameter steel or wood back plate all painted up. Add the little diamonds, maybe with different spacers for a 3-D affect. Sell the **** out of them.
    Aug 2009
    Whidbey Island, WA
    6
    I second the wine rack.
    Cave Creek Az
    803
    The holes are too close together making it very weak, especially if you start bending it. I see scrap.
    PA
    288
    Don't know how many you have or if this is a recurring item.
    But if you have a bunch, how about a decorative gate or coffee table.
    The issue of strength may be helped if you offset the pieces and weld them together where the welds won't show.
    Drawback is that this technique ruins the clean look of the pieces.
    Maybe weld 3 or 4 together as a triangular or square base and put on a piece of glass as a top.
    good luck and have fun
    Make a nice gate or a center section of one.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    Aug 2012
    Hermiston Oregon
    126
    Ninja stars
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
