Results 1 to 2 of 2
    Dec 2012
    27
    Default T Joint Aluminum bar - not plate - Advice Please
    Hi
    Needing advice please.
    I'd like to mig weld Aluminum 3/16,1/4 bar at T joint.
    Is this possible with a mig welder with spool gun using 110 outlet.
    Liking the arc of the passport plus - but could I use it for this ?
    If anyone could point me to a video tutorial showing how to tack
    weld 1/4 aluminum bar for armatures would appreciate it.
    I see a lot for plate - but nothing for bar
    Thanks, Stu
    8,325
    Better off looking at You Tube
