    Default Welding Exhaust Piping
    I recently put a new muffler on my truck, but the welds are hideous. The pipe is so thin that it's hard to make an effective weld without burning through. Any advice is appreciated since I'm doing it all over again when I get some larger pipe to use.
    Upstate SC
    129
    You aren't going to get an answer on here if you don't tell what type of welding equipment and setup you are using. Not because we're mean, but because it is impossible.
    cg
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    Smithy Lathe/Mill
    Jul 2010
    Salem, NJ
    262
    They are horrible looking because usually the metal / joint was horrible to begin with. The best advise I can give you is welcome to welding 101. Practice is the only thing that will make it look good.
    Jun 2012
    Tracy, CA
    175
    Quote Originally Posted by 7018fiend View Post
    Did you weld it after it was on the truck? I don't do exhaust systems that are already on the vehicle. I can't weld what I can't see. The bottom is easy but the top isn't east to get to with a welding helmet on.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Millermatic® 211 Auto-Set™ w/MVP™
    Spoolmate™ 100 Series
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Aug 2008
    103
    what kinda pipe aluminized or stainless steel ? i do a fair bit of exhaust if it was aluminized u need to clean inside and out to get a clean weld if not it will look like really bad
    1,568
    What machine/process are you trying to weld it with?
