Results 1 to 8 of 8
    Default Tungsten question....weldcraft vs weldmark
    has anyone used weldmark green pure tungsten? its much cheaper than weldcraft. is the weldmark any good? thanks a lot.
    anybody?
    Apr 2012
    10
    Go cheap ive used 2% for everything including aluminum. No issues
    just watched a welding tips and tricks video and he said the 2% lanthinated will hold up on ac and dc. can i just buy 1 type of tungsten?
    Jul 2008
    Flin Flon & Creighton area
    191
    Default green(pure) tungsten is primarily for aluminum , not used with inverter powersources
    Yes you can use 2% lanthanated tungsten ( Blue color) for everything. also 1.5 % lanthanated which are gold can also be used for everything. I use both but i have to say the 2% seem to take the higher current levels better and they dont seem to burn up or erode at all. they are really good. Seems like many welding books dont talk too much about them yet, mostly refer to Thoriated for steels and either pure or zirtungs for aluminum. The Lanthanated and Cerium electrodes are kinda "new" like the inverter machines they tend to use them with.
    I have a welding addiction
    ...the only stupid question is the one you didn't ask
    Feb 2009
    199
    Thumbs up 100% green tungsten on aluminium with Dynasty 350 works awesome
    green tungsten can be used with inverter welders on aluminum...i use it everyday on a dynasty 350...works awesome, so why say it can't be used??????????????
    Aug 2010
    Los Angeles
    1,099
    Quote Originally Posted by thunder71 View Post
    Nobody says you can't use it. Shucks, I could use it but why would it when my 2% lanthanated holds the point for days without splintering or spitting.
    You can tune an inverter tig to utilize any blend, so why would I shackle myself with low temp pure when I can take advantage of high temp blends. TriMix is my favorite but wildly expensive.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Feb 2009
    199
    low temp??? i run 235 amps welding anodized aluminum...i have tryed different types but the 100% works the best for ME...
    holds a point for days maybe with the machine turned off,ha green don't need a point and will never need sharpening, never
