    Default 1 type of tungsten all applications
    Well after research online, welding tips and tricks dude said that 2% thoriated and lanthinated will work for ac, and dc applications. the lanthinated holds the tip a little longer, but does not break as easy as the lanthinated.
    can i get away with buying just one tungsten?
    Sep 2009
    Canada
    193
    What machine are you using?
    Inverter or transformer tig?
    It is my understanding that the Ceriated tungsten will work on ac or dc current.
    All I use is 2% thoriated (red), but I dont tig with ac. Just dc- with a transformer power source.
    Pure tungsten is what I'd use for ac tig with a transformer power source.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Jan 2009
    SW Ohio
    135
    I use 2% lanthanated witn my Dynasty (inverter) and used ceriated with my Syncrowave 250. Not sure what works best with a sine wave machine.
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
    Jul 2011
    Huntington, NY
    118
    2% Lanthanated works for everything and works well. Thoriated makes little finger projections on AC and pure just balls up easily. Lanthanated makes a tiny ball on a sharp tip.
    Jun 2012
    Tracy, CA
    221
    I like 2% Thoriated for everything. Pure didn't last very long for AC. 2% Thoriated seems to handle a little contamination without having to re-grind as often.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™ (Sold)
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Nov 2012
    Northern Arizona
    542
    Has anyone ever tried the e3 tungstens?
