I use my Miller Bobcat 250 mostly in my garage for home projects. I am tired of having to push the thing outside whenever I want to weld something. Is there a way to plug it in so I can just run the welder off of the power from my house without having to run the generator?
Sorry if it is a dumb question, but I am new to these kind of welders. Thanks for any help or suggestions.
Results 1 to 10 of 12
12-11-2012, 09:37 AM #1
- Dec 2012
- 5
Can I run my Miller Bobcat 250 without the generator?
12-11-2012, 09:46 AM #2
Member
- Mar 2012
- 36
Nope. But you could always try stripping the decals off and putting 225 thunderbolt xl ones on and see if that works.
12-11-2012, 10:35 AM #3
- Nov 2012
- 4
You could make an exhaust extension to vent exhaust outside. Attach it to welder with a clamp or flange set up so it can be disconnected when you need to go portable.
12-11-2012, 10:53 AM #4
Just get your self a cheap buzz box
Kevin
12-11-2012, 04:01 PM #5
I know a guy that put a electric motor on an old lincwelder.. it wasn't very practical but it worked.
Originally Posted by Furmdog:297620
12-12-2012, 10:37 AM #6
- May 2011
- Bossier Parish La.
- 384
The rotor inside has to turn at the right RPM to get weld output. If you can find a way to do this besides using the attached engine then your in business. Weldon, in above reply has a solution for you by adding an electric motor, just not practical as he said.
You need to get an electric welding machine to do what you are asking, not an engine drive. When you get it, let me know and I will come take that screaming BobCat off your hands for no charge.
12-12-2012, 03:39 PM #7
- Dec 2012
- 5
12-12-2012, 06:47 PM #8
Does that bobcat weld so good that you won't buy a lil buzz box?
Originally Posted by Furmdog:297738
12-13-2012, 05:51 PM #9
- Sep 2005
- 4,242
Buy a DC buzzer, by the time you fart with exhaust, firing the thing up, putting gas in the electric would have paid for itself.
12-13-2012, 05:52 PM #10
- Sep 2005
- 4,242
In fact would likely go for a wire feeder if inside.
