Results 1 to 5 of 5
    Default Helmet Sensitivity
    I hooked up my 211 yesterday for the first time and began running beads for practice. I noticed that I could not see the front of the weld puddle while pushing. I had to estimate where I needed to stop.
    I adjusted the sensitivity on my Digital Performance hood down from 15 (recommended setting ) to 13. It did not seem to make a difference.
    I should be able to see the puddle and the immediate steel nearby, right? Should I keep adjusting the sensitivity down until I see it? I don't want to damage my eyes.
    Adjust shade not sensitivity.
    Use a shade 10 for GMAW. I've heard of folks who could get by with a 9 but I'm a bit fearful of that.
    Sensitivity determines when the auto-shade kicks in. I sensitivity is set too high the shae will stay dark just looking out the garage door. :-)
    I have the same problem. I couldn't see anything with my Hobart XVP so I bought a Digital Elite. Made a lot of difference. I also found that by not getting too close to the arc I could see better and I'm pretty sure a magnifier will help me as well.
    Also try running welder's chalk through the joint. That extra "white" can be helpful as well.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    Jul 2008
    Delhi, Ontario:
    1,950
    Yes, I agree, Adjust the shade till you can see the weld puddle clearly !
    I've been running shade 9 for the last few years.
    Prior to that I used shade 10 for many years .
    ...........Norm
    - Weldcraft WP26FV Tig Torch setup.
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Miller Econo Twin AC/DC High Freq.
    - Lincoln Power Mig 180C
    - Spoolgun.
    - Horizontal Steel Band Saw
    - DeWalt Chop Saw .
    Thanks guys, I probably meant Shade instead of Sensitivity; I don't have the helmet in front of me.
    It is good to know that the numbers are closer to 10 than 15.
    More practice is in order.
    Jul 2010
    Four Flags city
    236
    The eye doctor told me that if I continue to see the arc after I lift my hood it's not dark enough.
