    Dec 2012
    5
    Default Welding chromoly
    Everyone says to use 80s-D2. Just wondering what the difference is between 80s-D2 and 80s-B2? And would it work? Thanks
    Jul 2009
    Australia
    1,031
    What type of Cr Mo are you welding?
    Will you be post heat treating?
    What is the purpose of the unit?
    Ji
    Grip it and Rip it
    1,928
    The following was copied from this thread. http://www.millerwelds.com/resources...ll-Bar-Install
    Originally Posted by Gunner12R
    I've been welding 4130 race care chassis for nearly 25 years now and you should tack and weld it with TIG method. You can tack with ER70S6 if you must but it just causes you to have that tack in the middle of the weld that looks bad. For TIG use either ER70S2 or S6... Most people still swear by S2 but the mill spec will allow S6 to be used anywhere S2 is called for and if it's good enough for mill spec I think the race car world can allow it.. The original wire was Oxweld 65 if my memory serves me correct.. Anyway I like S6 a lot better because the higher silicon makes everything flow out a little nicer. Be sure and use a foot control and don't over heat the tubing because it makes it brittle. Also 1/16 wire is the choice size for this. ..
    I agree with Gunner12R on choice of filler......
    also...there are quite a few old threads to be searched... it is worth your while to read them... after all it is your neck in the balance......
    I would NOT use 309 filler for his application... this is an obsolete practice that was followed in the mistaken notion that the SS filler would make the 4130 welds more impact resistant and durable... I used to follow that practice myself until I was shown the error of my ways... It was common practice in race cars during the 1950's and 1960's... and also btw by the people that taught me (in 1968).... but testing and experience taught me better..............
    I would also seek out the tech inspector for your local sanctioning body for guidance..... after all he/she will grade your work and either pass or reject it...... so better not to stumble on issues that they consider important....
    BTW ... Here is a link to an AWS article regarding 4130 fillers....
    http://www.aws.org/wj/apr03/AWfeature.html
    Dec 2012
    5
    Building wheelie bars for a motorcycle. Using tig. And it's 4130
    Jul 2009
    Australia
    1,031
    Are you going to post heat treat?
    Ji
    Grip it and Rip it
    Dec 2012
    5
    Warm it up a bit with the torch then wrap it after. That's what I do when I'm welding 11/4 chrome at work.
    Jul 2009
    Australia
    1,031
    Is this for a rule based drag bike or just an after market part?
    Ji
    Grip it and Rip it
    Dec 2012
    5
    The bars are for a rule based drag bike. I've been welding pipe for a living for 10 years but have never tried chromoly yet. Just trying to learn as much as possible before I start
    Jul 2009
    Australia
    1,031
    Have you checked the rules from the association yet?
    Drag racing is as I read in the US governed by the Hot Rod Association.
    I know that they are the only association that state CrMo frames must be TIG welded but am unsure if the rules go further stating post welding heat treating and so forth.
    Check fabrication rules first.
    After all someones life may depend on your welding practise and your understanding of the rules.
    Ji
    Grip it and Rip it
