Results 11 to 14 of 14
    8,351
    That unit WILL NOT WORK on 247, if you read the data plate, that serial # is for plugging into 380-575 Vac ONLY
    Probably why it doesn't work....
    Oct 2012
    10
    In the manual download, it quite clearly states on front page 208/575 and 1 phase Cruizer...
    where u got that info from, please?
    Alas it didnt come with a cover for the fan, is that where the data plate would've been?
    **EDIT**FOUND IT IN MANUAL! yes, that cover wasn't on machine.
    Strange that it powers up though eh?
    Thanks anyways Cruizer
    Good work as ever.
    8,351
    I punch in the serial # on the tech only site, and it brings up the date of your machine and its specs. And it powers up cause your voltage and its min voltage are fairly close, but the unit won't do much after that.
    Oct 2012
    10
    Thank you!
