Results 1 to 10 of 14
    Oct 2012
    10
    Default Dynasty electric set up IN UK
    Hi all
    Finally got the Dynasty fired up.However it shows a "low line" error code and thats as far as i can get with it.
    I'm in the UK so i guess it may have something to do with the difference between OUR single phase setup and US single phase setup.
    Anyone got any ideas what i would need to do to get this resolved?
    The electrician that came and wired it up from my DB confirmed that there was 234V at the machine,so i dont know whats wrong?
    Help GREATLY appreciated (Cruizer,you like a challenge!)
    6,751
    Did you use the black and white wires at the machine?
    Oct 2009
    595 Riverside
    13
    I've been running my Dynasty on European power with no problems.
    Oct 2012
    10
    Default @ cruizer
    Yes sir,
    Black on top and white second...no red attached
    Oct 2012
    10
    Quote Originally Posted by Guardrail View Post
    How was power connected @ input panel?
    Oct 2012
    10
    Default Help!!!
    Anyone?????
    6,751
    Whats the serial#
    check your phase to phase voltage, these units don't care about the freq, and they will run fine anywhere
    Oct 2012
    10
    Default Croozer
    Thanks Cruizer, i knew you wouldn't let me down!
    LH400864L
    I will ask my sparky to check those values
    Regards
    Mat
    Oct 2009
    595 Riverside
    13
    Spanky, My 200 DX is wired so that the black and white wire go to hot and neutral and green to ground. The unit doesn't care whether the white or black goes to neutral or hot. All my machines, 2 Lincolns, 2Millers and an Esab, all US spec work fine. Sundown will come on here, call me name or two and say it's wrong. I'm just glad my welders and plasma cutters don't know thy are wired incorrect.
    Oct 2012
    10
    Talking
    Lol
    So it sounds like there may be another "underlying" problem?
    My thinking is, that i bought it from an auction for "not a lot" and dont know the history.
    I'm guessing the previous owner was using it via 3 phase and had "memorised" the settings for his last work?
    Now i need to clear those settings for it to accept new ones?
    I've done the "clear memory" process on startup, but that only works if the settings aren't locked....so if they are, how do i do a proper full factory reset, if there is one?
    Thanks in advance!
    Mat
