Results 1 to 3 of 3
Hybrid View
    Dec 2012
    2
    Default 180sd no gas flow / no tig arc
    I have a 180sd that's somewhere around 7 years old - zero hours on it. When I bought it new I hooked it up and struck an arc, then nothing. I never could get it to work again. Never had the time to mess with it till now. Here's what I've tested & know at this point;
    The digital display seems to work properly, with no errors.
    I was able to strike an arc using stick
    I tested the foot control (rfcs-14) for continuity in all 5 wires, ohm'd the rheostat and got smooth consistent readings
    There are 24v at the gas solenoid regardless of what I do with the foot control. It's always closed.
    I grounded the solenoid terminal without power & it opened and closed normally. So I think it's good.
    Ive checked for blockage in the gas line - I can blow through it relatively easily.
    Sound like an issue with the circuit board? I have not visually inspected it yet. Thanks for any help!
    Feb 2012
    NY
    49
    Have you checked the gas hose for a burn hole?
    Dec 2012
    2
    Quote Originally Posted by Gingerboy View Post
    I have. It's literally a "new" machine - just been sitting for quite a few years!
    I had a chance to take a look at the PCB - no evidence of a short or any burn marks. I'm stumped.
