Thread: need good tips
    Sep 2012
    seaford de
    406
    Default need good tips
    Anyone have any quick and easy tip to keep slotted holes in line with each other when punching with ironworker? Without building a jig
    Nov 2012
    21
    If I don't need a jig, I use my eyeball.
    Nov 2012
    21
    Unless they need to be "perfect" use a wall of the building or something that is straight like a edge of the ironworker that you can see while using the equipment. Draw you a line on the material and eyeball your marked line either parallel or perpendicular to reference.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by BearM:297379
    Thats what i ended up doing.. i only had 50 clips to make. I have a jig made but it wouldnt work for this particular job cause the slots were too close to the edge. I appreciate the suggestion
