Results 11 to 19 of 19
    Jun 2009
    Las Vegas Nevada
    132
    Based on my experience with a small Brit coupe racer I'd advise building a Halo style cage. The top hoop can be prefabbed and lifted into place while most of the vertical bars can be welded from below. I only learnt that from looking back at my cage and how it could be improved.....
    Miller Diversion 165
    1966 Bridgeport Mill
    Leblond 15x 35 Regal Servoshift lathe
    Solberga SE 1425 Drill Press
    Bigass Bandsaw
    Hydraulic press
    small surface grinder
    Belt sander
    Tons of grinders and hand tools
    Knife edge Balancing rollers
    Heat and AC in the garage
    Jags and racing Triumphs
    Mar 2013
    Speaking of Camaro cages, friend of mine's brother in law runs a Camaro at the Texas Mile. He recently upgraded his cage and he's glad he did.
    Before
    After
    That is what happens when you flip at 240.
    Jan 2009
    SW Ohio
    135
    What caused the flip?
    Dynasty 300DX
    MM350P
    Hobart Handler 120
    Smith LW7, MW1, AW1
    Smith AR/He Mixer
    1,919
    This car finally showed up last night complete with a whole laundry list of things to do besides the cage. I really don't need any more work at this point but it's here so I'll post some pics when I start.
    1,919
    Started yesterday. Got the main hoop & rear down bars fitted. Formed & welded the floor plates for them both. Going to tack the bars, remove & weld them, reinstall. Then I will fit the halo bar after bending correctly since one bend is wrong & front down tubes.
    1,919
    I can't believe this thing has been in my shop this long. Been working on it in between other stuff & almost finished up the cage today. Waiting for the owner to reinstall the dash & then get the new seat mounted so I can determine the height of the harness bar. Once the harness bar is in I can make the rear seat support & put the braces from the main hoop to the tunnel & it will be done. Hopefully soon so I can get it out of here.
    Job was way more of a hassle than I thought. Seems like it took forever but it is coming out nice. I will say I would think twice before doing another one. I bought a RCCS-14 finger control (north/south) for this job but I can't get used to it at all. Even just sitting at the bench it is very hard to ramp up & down. I think I would rather have an on/off switch.
    Since it is chrome-moly it all had to be tigged. The worst was the front down bars to the floor. No matter what I did I couldn't get all the way around. Tried all the tricks I know, mirror, tungsten stick out but just couldn't get my hands & helmet in position to see & weld about 3/4" in the back side. So I finally figured out a way to "cheat". I tigged what I could & then was able to mig what I couldn't using a mirror. Then I went back with one hand & washed it in with the tig. Looks good.
    1,919
    I welded the floor plates to the bars on the bench for that location. I figured running the Mig in tight quarters to weld the plate to the floor was much easier that trying to Tig way in there.
    I used a helper to run the pedal for me rather than going with a finger control. It took a little bit to get the two of us coordinated but worked out OK in the end. I wouldn't want to do it that way if I needed to make a living welding cages but for my one off in the driveway it was fine.
    1,919
    I thought about welding the floor plates onto the tubes first but by that time it was to late, I had them welded to the floor already. I wish the cage maker (Midwest Chassis) included instructions or helpful hints with the kit. It would have saved me time in figuring it out. I will say any question I e-mailed to him he did answer quickly & the halo bar was bent wrong & he replaced it quickly after I sent him a pic explaining what was wrong. Earlier in this thread I mentioned that the customer service/shipping of this kit was not the best but I do believe that he has taken care of that. I have had nothing but good service in dealing direct with him. The fit was great as no adjustments were needed other than trimming & notching.
