Results 1 to 2 of 2
    Dec 2012
    California
    1
    Default Diversion 180 Questions
    Are you able to use any gas lense's on the Miller Diversion 180? without switching out the torch or torch head. And Is the machine able to weld titanium?
    -Thanks
    Aug 2010
    Los Angeles
    1,178
    Quote Originally Posted by TIGMASTER555 View Post
    -Thanks
    Absolutely on both counts. The Diversion uses an aircooled torch, WP17 style I believe. I use 17 series gas lenses on the torch that came with my Dynasty. Works a treat. The gas lenses I get are "stubby" gas lenses.
    Welding titanium is very much like welding stainless steel. The Diversion can do both including Aluminum, magnesium, bronze, cast iron, even lead if you must. Zinc not so much. Brass is a bit tough, but can be done too.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
