Results 1 to 10 of 10
Thread: mm211 or mm212
    Nov 2012
    4
    Default mm211 or mm212
    Considering purchasing one or the other. Hobby welding w/ ability to do some occasional aluminum work. Quotes from lws puts the 212 about $900 more than the 211 both with the required aluminum extras. Does the 212 have the added features and abilities to make it worth the extra money.
    3,658
    The 212 has wheels and a bigger duty cycle and costs more. If you can swing it $$$$ and have the room for a wheeled welder go for it...Bob
    Dec 2011
    West Central WI
    3
    Default 211 vs 212
    I have a few welders for my business, but my usual go to welder is the 211. Simple, easy to use and does a nice job. Its also portable and has mvp capability....can't recall if the 212 has a mvp. It's hard to beat the 211 s ability in a small portable package! Hope it helped!
    The Best!
    Mike
    Aug 2012
    Hermiston Oregon
    122
    Own the 211 & used the 212 in shop
    Duty cycle not an issue with 1/4"
    Portability big +
    My vote 211 hands down.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Dec 2011
    231
    I note in the specs that the 211 is specifically limited to the 4043 series of aluminum wire while the 212 is not. Both say they will weld 3/8 aluminum. Is this limitation on the 211 only a function of the duty cycle or is there something else that leaves the 211 not recommended for say, 5356?
    Doesn't matter if 4043 will do what you want to do and the ease of transport of the 211 certainly is a plus if your going someplace regularly with you welder.
    Meltedmetal
    On the other hand the 211 claims to be able to weld thinner stuff if that's where your at.
    May 2011
    Bossier Parish La.
    385
    Quote Originally Posted by tsal357 View Post
    For hobby welding the MM211 will probably do everything you need to do. Duty cycle shouldn't be a big concern, since your not on a strict timetable to complete a project for a paycheck. Portability of the 211 can be a plus factor over the 212, it's easier to take to your buddy's house to do some welding there. The $900 you don't spend on the 212 can buy you plenty of saws, clamps, grinders, project steel, wire, sheilding gas, an O/A torch etc.
    Nov 2012
    4
    Thanks guys. I ordered the 211 today. Portability , mvp and price made final decision. Gun on demand was tempting but my guess is I wont be doing aluminum regularly. Thanks again.
    Aug 2012
    Hermiston Oregon
    122
    Quote Originally Posted by tsal357:297337
    You'll use that mvp plug more than you realize. Enjoy
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    May 2011
    Bossier Parish La.
    385
    Now, you need to pay us back by showing us what you have made with this new playpretty. Besides just running beads on flat stock.
    Dec 2012
    52
    The 211 I just got says it'll weld 2 grades of Al wire, but I've only found the cheap one locally. I started this with the Lincoln I was borrowing, and finished it with the 211:
