Results 11 to 15 of 15
    Mar 2011
    torrington, connecticut
    22
    CV mode
    And no reason to change polarity unless your running fluxcore
    cruizer, i am confused, if the sae 400 is a variable voltage machine wouldn't you run the 12vs on constant current setting? (? on your post #9.) thanks tom.
    6,751
    Quote Originally Posted by cws612 View Post
    I have ZERO idea on which SAE400 you have.
    A code # would be handy for me to pull up the correct spec's
    Mar 2011
    22
    my apologies, i assumed boomertoo was referring to a engine/generator sae 400. i never knew them to be other than stick machines (cc). i am not questioning you just your response. if the sae 400 is a variable voltage stick machine, should the 12vs feeder control be set on cc? thanks, tom.
    6,751
    Code# so we can be on the same page, there is about 6 different SAE400's
    Jul 2008
    6
    Mine is an gasoline engine driven shield arc sae-400
    serial a-701394
    code 7175
    There is no model number that I can find
    I would appreciate any info and year built you can find
