Results 1 to 10 of 15
    Jul 2008
    6
    Default x-treme 12 vs with lincoln 400 sae
    Hi all can I run x-treme 12 vs with lincoln 400 sae
    It says on the 400 sae tag that its variable ocv .
    I just got the 12 vs and a bottle of trimix
    I need to weld quite a bit of stainless and dont want to kill the 12 vs
    if the welder is not compatable.
    Steve
    May 2012
    chilliwack BC
    32
    I kinda have the same problem I have a 12rc suitcase and was wondering if I could use it with a vantage 300 or 400 or do I have to use a ln-25?
    Mar 2011
    torrington, connecticut
    22
    Quote Originally Posted by boomertoo2 View Post
    Steve
    12vs should be fine with sae400
    Mar 2011
    22
    Quote Originally Posted by pressurewelder View Post
    12rc requires a constant voltage setting on the machine its hooked to i believe. however the ln-25 should work no prob.
    Oct 2004
    Edmonton, Alberta
    6,755
    The 12RC will NOT work on the Lincoln cause there is NO 24Vac to run it.
    OCV, merely means Open Circuit Voltage, zero to do with Constant Voltage which unless you have a CV module on the SAE, it's not there
    May 2012
    chilliwack BC
    32
    Thanks cruiser. I run it (12rc) with a tb302 and it seems to run great. Iam I doing things right? And why wouldn't a 12k machine be able to run it? It looks more and more the 350pp is the way to go it will run the vs and rc
    Oct 2004
    Edmonton, Alberta
    6,755
    Every machine will run the VS suitcase, but only those having 24Vac will run a RC
    Jul 2008
    6
    If the SAE 400 is variable voltage should I use the CC or CV setting on the 12-VS ?
    Also is it ok to reverse polarity when using the 12-VS ?
    Oct 2004
    Edmonton, Alberta
    6,755
    CV mode
    And no reason to change polarity unless your running fluxcore
    Jul 2008
    6
    Thanks much
