Results 1 to 8 of 8
    Apr 2006
    TAXACHUSSETTS
    1,504
    Default Hiway Sign Structures
    Few pics of some night work i,m doing.All 4"x4" galv. angle and 1/4"plate,And a 4"t steel that sign mounts too.Doing the drilling also thru the bridge girder 15/16" holes for 7/8" A-325 bolts galv.Then weld in all cross bracing to tie 3 brackets together.Other crew assembles sign and mounts i,m just on the steel.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Jan 2012
    Metro Detroit, MI
    185
    Good stuff I like the pictures and description painted the picture beautifully. How many are you building? Big contract? I hate welding galvanized.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Apr 2006
    TAXACHUSSETTS
    1,504
    Got a few more to do working sun- wed night this week.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Apr 2006
    TAXACHUSSETTS
    1,504
    Quote Originally Posted by Rezeppa View Post
    Back on this week just finished the three at exit 6 were moving to exit 7 sun- wed nite.Got 3 to do there i think were done.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Apr 2006
    TAXACHUSSETTS
    1,504
    Default few more pics
    This is a few more pics of the bridge at exit 6.First pic is demo of the old sign structure.That is a guy up top cuttin with a gas powered chop saw.Second is the new one up on the girder.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Jan 2012
    Metro Detroit, MI
    185
    That's Awsome I was talking about this at work because my company has done some highway paving and I asked about bidding the sign work and I found out they are installed in Michigan by the MDOT pre fabricated in the sign manufacturing shop according to my contact but idk if this is true now after your post
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Stihl TS 420
    Timfrank88@live.com
    Apr 2006
    TAXACHUSSETTS
    1,504
    The co. i work for does not fabricate the signs or the mounts they are hired for the install only.Then they sub me in for the steel part.They needed a certified welder to do that part of the work plus they don,t weld.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Aug 2004
    Milan Michigan
    1,863
    Adams Welding, You need to be care full of this.
    Some fabricating friends of mine did some big highway sign posts out of pipe that was approximately 12" diameter and they spliced one of the pipes together, ground the welds smooth and sent them out to be galvanized, The DOT would not accept the posts because they were spliced. ( The galvanized showed the weld )
    This happened about 15 years ago.
