Thread: new start!
    Nov 2012
    Default new start!
    Good morning all,
    Im currently planning to build a sheep handling system which will consist of hurdles and gates and once i get brave maybe a shedding gate or weigher..
    i'll be running off my home 13amp fuse so 130amp max setting should keep my fuse in trak.
    I will be making these hurdles out of 20mm box x 2mm thick.
    what size wire would you reccommend to ensure good weld with Mild steel as above size?
    thanks
    C
    Nov 2010
    265
    Quote Originally Posted by harper View Post
    Good morning all,
    thanks
    C
    Cool! A mystery welder.
    I am going to guess that this is a MIG process and you don't want to use shielding gas so here it is:
    .035" Self Shielded Flux Core wire (E71T-GS) @ 145-155 ipm @14 15 Volts.
    Nov 2012
    Quote Originally Posted by Dipsomaniac View Post
    Sorry for the mystery..
    you are correct- Mig 160 amp and will be used with Agrosheild Universal.
    Mig is Clarke 160TM if that helps but i doubt you get this in the states.
    Im UK based but this site has great detail so thought id join in and hopefully show my wares when i get onto starting..
    thanks for the reply
    cheers
    C
    Dec 2008
    Arizona
    812
    Before you start, buy a handful of spare fuses!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    561
    Quote Originally Posted by nocheepgas View Post
    He's on 220v @ 13amp fuse, should be ok up to about 16v on a mig.
