Results 1 to 4 of 4
    Nov 2012
    1
    Default Millermatic 211 question
    New to the forum and the welding trade. Just purchased the MM 211 and have used it to build a welding table. The welder seems to be working just fine as far as the beads im laying down, but the machine seems to make a lot more noise from the wire spool drive or wire drive rolls. Is this normal from the MM 211's or is this a problem. Previously welded with a Lincoln wire feed that didnt make this much noise. Any feedback welcome!
    Aug 2012
    Hermiston Oregon
    278
    Couldn't tell you without hearing it.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    May 2012
    110
    I just ran mine tonight and didn't hear what I felt was much sound if any. Is the wire spool cranked down a bunch making the noise? Or does it sound more like a drive motor sound?
    Is kind of a squeeling noise? If the wfs is cranked is does that.
