    Oct 2012
    Default XMT 304 CC and CAC-A
    My first post on this forum, I have an XMT 304 CC. In the specs it lists this unit as CAC-A capable but I have not read any threads of it being a viable plasma cutting option for the 304. Does anyone have a suggestion how this is set up in the XMT?
    Sep 2006
    south west Michigan
    81
    By reading your question it seems like you want to plasma cut?
    If so then you need a DIFFERENT machine. Big difference between carbon arc gouging and plasma cutting.
    Oct 2012
    Default Thanks for the reply
    Thanks for the info.
    Sep 2009
    Canada
    195
    The xmt 304 will work for a carbon arc gouging power supply. I would prefer a big beefy transformer for this job but the inverter xmt will work.
    The xmt 304 will not and is not a plasma cutter.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
