Results 11 to 20 of 32
    Jul 2010
    Salem, NJ
    280
    Quote Originally Posted by snowbird View Post
    I don't remember exactly wich is what but they are named: left flasher, right flasher, parking and GROUND.
    White: Ground
    Brown: Park/Brake
    Yellow: Left Turn
    Green: Right Turn
    The problem with some/most small trailers is they use the fenders/steel for ground, and at your tongue the white/ground is only 12" long. I always run my grounds directly to the light to prevent rusting/dielectric issues.
    Trailer diagram
    Mar 2011
    st-eustache qc.canada
    230
    Sorry to disagree but brake and park can not be on same wire since 2 different filaments in bulb are concerned.
    check there for all acurate datas (not from me)
    http://www.offroaders.com/tech/trail...ng-diagram.htm
    Oct 2006
    Illinois
    611
    I had same issue. 3 wires on LED, I took the white wire and grounded it to the metal where light was mounted using a separate screw. I did this at each light and it worked.
  4. #14
    Aug 2012
    Hermiston Oregon
    265
    Quote Originally Posted by Country Metals:296946
    I have never heard of a 3 wire system, only a 4 wire system and I have owned over 8 trailers in my short 15 years. There is flat 4, round 4, round 5, now flat 5, round 6, round 7, soon round 8, air brakes. You need Ground, Blink, Brake, Running. No system that I have ever worked on can have blink and brake on the same wire because they would conflict each other.
    That is probably why the lights don't work when connected on the trailer, and why they do work when blink/brake are disconnected. You are having a conflict on the towing vehicle.
    I have a four wire setup. My leds have 3 wires. And I've tried every way to wire it. = no running light's
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
  5. #15
    Dec 2011
    406
    So if you remove a lamp assembly and jumper it to a battery . white to neg, then either the brake or the running lights will light but not both together?
  6. #16
    Jul 2010
    Salem, NJ
    280
    I was off because I forgot these were LED's.
    If they work properly at battery and not connected on trailer, what vehicle will this be connected to? Just saying because some vehicles have fuses built into just trailer lights. I have seen them in the dash and at the tail end of the vehicle.
  7. #17
    Oct 2006
    Illinois
    611
    What make, model ,and year is the vehicle you are connected to ? On some newer vehicles, the LEDs will screw with the pulling vehicle's electronics and not work properly. The LEDs don't pull as much current as incandesants, and the computer will think the bulbs are burned out or unplugged. There are adapter boxes to fix this problem, though. Don't know if this is true or not.
  8. #18
    Mar 2011
    230
    Smile
    your 3 wires are same as the original bulb you replaced. as jiganitor mentioned, if you flow the current the wrong way a led won't work, if they had to be used with a resistor and you did not, they might be burned.
    Were the previous bulbs working in all modes?
    i still have a doubt on the ground...
    image is a thousand words ...here is a basic one. (very very basic ;o) )
  9. #19
    Aug 2012
    Hermiston Oregon
    265
    Quote Originally Posted by BD1:296980
    Its. A 97 Chevy silverado. I haven't found a fuse dedicated to the towing lights.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
  10. #20
    Aug 2012
    Hermiston Oregon
    265
    The regular. Lights worked. But I wanted to upgrade the lights to led. Am I missing something?
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
