Page 1 of 3 123 LastLast
Results 1 to 10 of 32
Hybrid View
    Aug 2012
    Hermiston Oregon
    286
    Default help with my trailers lighting?
    I just updated the lights on my tool trailer from older bulb style to led. My signals & brakes work but my. Driving lights don't at all. I tested the connection to the led and I'm getting power. Ok. Its three wires. White-ground. Red-blink&brake. & black-driving lights. I tested red & black by them selfs straight to the battery and they work but when wired on trailer Im not getting my driving lights. Any help is appreciated. Thanks
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Jul 2009
    Australia
    1,031
    Trailer light problems are usually bad earth.
    Run an earth as a test wire and see what happens.
    Ji
    Grip it and Rip it
    Aug 2012
    Hermiston Oregon
    286
    Did it. Didn't fix it.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Jul 2009
    Australia
    1,031
    So you have Pos and an earth to the LED and still no light?
    Ji
    Grip it and Rip it
    Aug 2012
    Hermiston Oregon
    286
    Letme explain while wired on the trailer. I get no driving lights. But. if I disconnect the brake&blinker wire my driving lights work. I've checked for a short & found non. ???
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Jul 2009
    Australia
    1,031
    Did you check at the car connector?
    When checked at the LED did you use a light bulb or a multi meter?
    Ji
    Grip it and Rip it
    Aug 2012
    Hermiston Oregon
    286
    Quote Originally Posted by Jigantor:296933
    Ji
    Checked with light probe. Have power up to the led.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Jul 2009
    Australia
    1,031
    LED is a diode.
    Diodes allow current to flow in only one direction.
    Is the positive lead connected correctly?
    Ji
    Grip it and Rip it
    Jul 2010
    Salem, NJ
    291
    I have never heard of a 3 wire system, only a 4 wire system and I have owned over 8 trailers in my short 15 years. There is flat 4, round 4, round 5, now flat 5, round 6, round 7, soon round 8, air brakes. You need Ground, Blink, Brake, Running. No system that I have ever worked on can have blink and brake on the same wire because they would conflict each other.
    That is probably why the lights don't work when connected on the trailer, and why they do work when blink/brake are disconnected. You are having a conflict on the towing vehicle.
    Mar 2011
    st-eustache qc.canada
    243
    Default 4 wires needed
    If you have what we have most of the time on american made trucks, the same bulb that is lit when braking and blinks when flashing, you absolutely need 4 wires wich on the connector are white, green,brown and yellow.
    I don't remember exactly wich is what but they are named: left flasher, right flasher, parking and GROUND.
    As said before 90%+ of the time ground is at fault, never trust the trailer body or coupling to carry ground, there is to be a good wire ground all the way to the bulbs.
    If the vehicle is equiped with a dedicated flasher bulb at the rear (yellow lens) then you need a signal converter from auto-part store.
    When the ground is bad flashing mode dims the park lites and all seem to work confusely.
    hope it helps, my .02
