Results 11 to 15 of 15
    1,890
    Flux core (innershield) wire vs. solid. Flux core generally uses less voltage/amps than the same size in solid. This means you should turn the machine down. Polarity is usually also different between the two. Solid= work lead to - & gun to +. You would switch for flux core most of the time, gun to -. Knurled v-groove rollers work better for flux core as stated above. Smooth v-groove for solid. Flux core uses a longer wire stickout than solid. About 1" for fux, 1/2" for solid. Keep the nozzle on or get a flux core nozzle when running flux core to protect the diffuser. I like splatter spray more than nozzle dip. They sell it at GTS-Welco. No need to soak it, just spray it once in awhile. Get yourself a bunch of extra tips & also a torch tip cleaner to clean your mig tips. No reason to throw them away until they get worn. Don't be afraid to remove the nozzle & clean it with pliers or a screwdriver.
    When changing rolls of wire it's a good idea to blow out the gun with compressed air.
    The above are just generalizations. Check the wire mfg. specs & the door chart is always a good starting point.
    May 2012
    110
    Great tips all.
    I plan on getting a knurled drive roll - I'll search the miller website, cyberweld etc. As per that - I read the manual yesterday afternoon and noticed the 'recommended starting point' for the drive roll pressure arm was a setting of "3" - out of "4". I had mine at "1" even less, possibly 1 1/2 as well. So I went home and cranked it down - and it felt like it took about 300 cranks (exageration) to get it down to the "3" - was not comfortable with that much - might bring it back up to say - "2" next time I run it - but plan on getting a knurled drive roll anyway.
    Splatter spray vs. noz dip - good to know - may just pick up both. Found myself brushing the nozzle gently with a wire brush between runs to get the junk out. also using some mig welding pliers gently.
    1,890
    With a knurled drive roll you will use less tension. I usually set the tension just past the slippage point. I always try to keep the gun as straight & untwisted as reasonably possible.
    Aug 2009
    Ocala Fl.
    46
    Your 211 is a great welder and the manual for this welder will get you whwre you need to be to set this welder up.If you are useing the Brass nozzle that came with your welder for flux wire?? then you need to change it to the black nozzle for flux wire.As for your drive roll if you open your door on the the welder down on the bottom you will find the part number for the Knurled drive roller. Auto Set will not work with flux wire, and the Auto Set when used with Gas, this setting is something you will have to work with it is not set in stone for the settings.
    Wa
    620
    Quote Originally Posted by jfk92 View Post
    Great tips all.
    If you have the tension too light that could lead to slippage which could also be contributing to your spatter problem. There is a correct tension that you must balance. Nobody can say what that may be as wire, rollers, and the tensioner all vary.
