Ya i found the knob in the weld shop. It was sitting on a shelf lol. When i turn the knob the inner part turns with it. Im going to switch it to the lower setting and see if i notice a difference then.
Also cope i sent ya my address, and once again thanks so much.
Results 21 to 30 of 33
Thread: Mm200
11-28-2012, 09:29 PM #21
Member
- Nov 2012
- 31
11-29-2012, 04:32 AM #22
11-29-2012, 06:13 PM #23
- Sep 2005
- 4,247
That machine has a lot of poop, if you want to run it hard an 8 wire I believe, 50A breaker, if your demand is modest it could run from a 10.
11-29-2012, 08:02 PM #24
Member
- Nov 2012
- 31
Well i just found this out today, i cant wire in a 50a 220 due to the fact its a rental. The dryer is right inside the door so il be making a cord for it following an online guide. Also if i get ambitious i might paint it with some ppg paint and clear it. Iirc miller still makes the decals. Also a pic of internals, thoughts?
11-30-2012, 04:53 AM #25
11-30-2012, 07:54 AM #26
Member
- Nov 2012
- 31
Should be pretty simple, I worked with a contractor for a year so hopefully i didnt forget everything when i moved to a metal shop haha
So hopefully last question, this one not so dumb haha. Since il be running it off a 30a breaker should i set the voltage input to 200 or 230? (I have the 200v/230v not 230, 460). Or is that for something completely different..? Il be welding mostly 3/16 and every once in a while 1/4 inch.Last edited by ZJones1994; 11-30-2012 at 08:14 AM.
11-30-2012, 10:14 AM #27
12-02-2012, 03:15 PM #28
Member
- Nov 2012
- 31
Cope-The gun came in yesterday, it looks amazing and il be able to test it this week
i spent all day doing plug welds at work with a 250 on its last leg haha
12-02-2012, 05:50 PM #29
12-08-2012, 04:11 PM #30
Member
- Nov 2012
- 31
So i got it home, working on fixing it and i cant get the voltage range plug to come out. (On the face of machine) any advice
