Results 1 to 3 of 3
    Nov 2012
    Tallahassee Fl.
    9
    Default Syncrowave 250 torches
    I just got a syncrowave 250. I don't know if I can hook both the tig and stick torch up at the same time and use one at a time or do I have to just hook one up at a time. Thanks Matt.
    1,907
    They can both be hooked up at the same time but be careful as they will both be "hot" when the machine is on. For instance when the machine is in stick mode the tig torch will also be live. If it touches anything it will arc out. Generally this is not done due to that reason. To easy to have something arc out somewhere.
    Nov 2012
    Tallahassee Fl.
    9
    Thank you. For the answer.
Tags for this Thread
